Kozzie2020
My boat has a fully enclosed double bimini. The black material is all solid Sunbrella and the grey windows are made from a product called Vistaweave 95 which only allows 5% UV through, so it’s very fine mesh and only a little rain mist will enter the boat if it’s windy.
My problem is every time it rains I get water in the lounge storage compartments, sometimes half a bucket per compartment.
I have noticed that any water that falls on the lounge is drained externally so no water can enter that way.
Does this mean the water might be entering through the bottom side drain holes, maybe the wind is pushing the water between the bottom fence rail and the deck and straight in through the bottom side drain holes? The water then pools to the end of each compartment because my boat is leaning to stern.
Strange as this may sound but if I silicone the bottom side drain holes could this fix the problem?
Has anyone else had this issue?
