Welcome to Club Bennington
Login Register
Wave damage to front panel
Discussion in 'Pontoon Forum' started by Mat240, Aug 11, 2013.
  1. Mat240
    Mat240 Member
    19
    3
    Hello,
    Has anybody ever had wave damage to a front panel? We were on the lake yesterday and the winds created some rough waves and some pretty good size rollers. Deciding to turn back and just stay in our bay we took two good waves to the front that were enough to soak us all on the boat. Upon returning to the dock, after tying up we notice the left side panel on the front of our new RCW 22.75 was push in and wrinkled. At the very bottom of the panel you can see where it seems to have pulled out of the bottom rail slot where it looks to be factory crimped in. Called the dealer today and he said yes, a good wave could do it. Has anybody else experienced anything like this? Just doesn't make sense to me that a wave, no matter how hard it hits could do this. I mean its a boat, there are waves in the water. I would think the panels would be reinforced to expect these kind of conditions. I steer through the waves and wakes at a 45 degree angle best I can, I throttle up to keep the bow up when approaching the large ones. I'm having a hard time accepting a wave can push in the panel. The rails are all fine, just the panel has damage. Any opinions will be welcomed.
    Thanks
    Mark
    LakeRat1 likes this.
  2. Mat240
    Mat240 Member
    19
    3
    sonnyhad likes this.
  3. TomS
    TomS Well-Known Member
    2,966
    944
    Sanibel FL
    Sorry to hear this, especially since those panel colors are identical to mine! Unfortunately it is very common, especially in places like Lake Of The Ozarks with big cruisers making huge wakes. Talk with your insurance agent is this sort of thing is usually covered other than deductibles. Small dents can be repaired by a paintless dent service (for cars), though that looks fairly heavy so the whole corner fence panel probably needs to be replaced.
    Spoiledrotten likes this.
  4. Mat240
    Mat240 Member
    19
    3
    Thanks TomS, I will be contacting my insurance co. I feel the waves that hit are not so uncommon on our lake (Winnipesaukee in NH)with winds 15 to 20 knots. I'll be worried about this happening again every time the water gets rough. Seems like it was too easy.
  5. TomS
    2,966
    944
    Sanibel FL
    I should have said it's fairly common on ALL brands of pontoon boats, sad to say it's the nature of the thing. We're on our 3rd pontoon, the latest being an ESP so the bow always stays a lot higher due to the extra buoyancy, which helps a lot. We're lucky as we don't encounter those type of waves on our small lake other than some of the wakesurf boats.
  6. keithkz
    keithkz Well-Known Member
    1,052
    177
    Michigan Center, MI
    I had my boat out on Torch Lake in northwest Michigan (lower peninsula) about 3-4 weeks ago now ...Michigan's largest inland lake. On the last day there we had some pretty high winds which created some big waves but my boat being a 2575 tritoon did very well in it. A brand new 23' Crest didn't fare too well. It was only a 2-toon boat and like I said, a little shorter than mine. They said they had 9 people in the boat and all but two were in the back when they hit a wave which dented the entire front panels. I wanted to tell him there is no way in hell I would be on that lake under those conditions in a pontoon boat any shorter than mine. Made me very glad I got a tritoon and the longer model. It's overkill for the lake I live on but this was the 2nd trip I've taken with it now on large inland lakes in Michigan and it is in it's element in rough waters.
  7. SEMPERFI8387
    SEMPERFI8387 Moderator
    9,584
    3,872
    York, Pa
    As others stated, no matter the brand, a big enough wave, and it's gonna hammer those front panels. Sad to say, it's not a "Bennington" issue. I have seen numerous posts on other forums with same thing. The only thing you might try is remove front lounger and try to pop it back out best as possible, but being it popped out of the slot, might be a little harder to get it back together. Even though these boats can handle pretty rough conditions, there's only so much that can be expected of their design.
  8. 1TOON3
    1TOON3 Member
    16
    I had the same exact dent in my 2274GL last year when I was squeezed to the shore by a couple WOT cruisers( sometimes I think they cause big wakes on purpose and could care less about pontoons, fishermen,or whatever) Now if I encounter that type of wake I just let it roll me sideways, I don't try to head into it at all. I was able to pull the seat and push the dent out with a piece of 2x4 and a rubber mallet. The creases still show, but the dent is gone and someone with autobody shop skills probably could address those. Couldn't justify pulling it for replacement and the costs associated, when it could happen again, so I just live with it.
  9. Mat240
    Mat240 Member
    19
    3
    Thank you all for your answers. I will see what my dealer says soon. I pull her out of the water after September.
  10. LakeRat1
    LakeRat1 Well-Known Member
    65
    6
    Osage Beach Missouri - Lake of the Ozarks
    The same thing happened to me this past July, same corner...... Made me sick enough that I am ready to sell my boat and get a Q model....... Keep us posted on what insurance says and the estimate to repair if you would......
    I was think a PDR person could pull the dent with a suction cup, versus pulling the seat out and pushing it out..... like was stated, there will be a seam left.....
    gudtyme likes this.
  11. Reel Ax
    Reel Ax Well-Known Member
    52
    4
    Ohio
    Has anybody tried  to pull the dent out with a suction cup?
    1TOON3  how hard was it to remove the seats? Are the seats bolted or are they screwed in with self tapping screws
  12. Bull
    Bull Well-Known Member
    173
    16
    "On Golden Pond", NH
    I am mostly on Squam but get to the big lake a few times a yr.....the last couple weeks have been the perfect storm. Tons of big boat, wind and rollers in multiple directions.Last week we were in a similar situation. We loaded the stern and put a little extra weight in the corner opposite the direction of travel.
    3 logs definitely help,,,,,,
    I am curious as to how the dealers handles this.
    If you ever want to explore Squam, I'm your man
  13. JSM
    JSM Well-Known Member
    81
    7
    Indianapolis
    That would make me ill. Fortunately I have not seen anything that big here on Morse Reservoir in Indiana. Based on what I've read here the only prevention would be three tubes or the 32's. Also going to a Q with the sloped front ought to do it. The wave would most likely roll right up the slope and soak you, but not likely to dent in as it would be a glancing blow.
  14. FarNorth
    FarNorth Well-Known Member
    99
    3
    I can vouch for this not being an issue in our Q. We have probably stuffed the bow 3-4 times now and had at least 20 big waves come over the front. We are usually only going 15-18mph when the water gets rough but so far no troubles.
  15. JSM
    81
    7
    Indianapolis
    I noticed there is a thread for possible new ideas. However why not continue here with that thought. I think the next new development would be easily removable panels so that if damage occurs, bingo! Want to change your look, bingo! Want to up date etc. you get the idea. There has to be a way to mount the panels so that an owner could easily change them out. And what an additional revenus stream to Bennington and the dealer network. Increased parts sales.
    DD2075GL likes this.
  16. TomS
    2,966
    944
    Sanibel FL
    Someone on my factory tour asked this question of Mike, the expert there. He said they've explored that several times, but it would compromise the rattle free nature of their fixed panel system, which to someone like Bennington where quality is everything, just was not a good tradeoff.
    Link likes this.
  17. JSM
    81
    7
    Indianapolis
    I like quality, thus the Bennington. However, I still think there is a way.
  18. zforsyth
    zforsyth New Member
    Happened to us too.
    How do I post a pic of the easy/cheap/attractive fix I'm using?
    DD2075GL and zforsyth like this.
  19. cwag911
    cwag911 Moderator
    5,995
    2,101
    Put pics in your gallery then go to options and use the links.
  20. DD2075GL
    DD2075GL Active Member
    33
    7
    Little Ossipee Lake, East Waterboro, Maine
    I just noticed the exact same thing on our boat. I couldn't figure it out so I looked here and found this post and comments. Zforsyth, what was your fix?
Share This Page
