1TOON3
- Messages
- 16
- Reaction score
- 2
Curious if anyone has changed the water fuel separator standard on Yamaha engines. Mine is located under the deck just below the fuel tank (which is located in the rear storage and changing room area). There does not appear to be a shut off valve between the fuel lines and the separator, so I assume I just unscrew it and gas doesn't come flowing out of the tank through the line to the separator. I looked at a Youtube video on the subject and they had shut off valves or the separator was mounted above the gas tank. Any info would be appreciated. Thanks in advance!!
