What did it (boat) come in at weight wise and what is the # capacity of the trailer if you don't mind me asking? How did it pull? I am researching trailers and have mixed feelings between a tandem and triple axel. Not knowing the weight is the problem right now. I will ultimately pick one with a larger weight capacity than I need but just curious.
Well, just speculating but with the boat at around 3200 dry, the motor at 800 and with fuel, probably around 4500-5000 or so. The trailer is rated at 7400 so it's nowhere near it's capacity. The boat/trailer tows awesome, hardly know it's back there. I have airbags on the truck so with them pumped up to about 40 lbs. the trailer sits perfectly level with no tongue bounce.
