Home built tie off
Remediation
Home built tie off
The boat is too wide for the available slips, so I have to dock on the walk way. I looked at whips but they can break in the storms up here. I used gas pipe, angle iron, 4" clamp from Tractor Supply and docking rope. Drilled a hole in the pipe so it can pivot on the clamp and mounted the clamp in the angle iron and bolt the angle iron to the dock.
Canada 2015
Remediation
