2000 2275FS Parts Manual & Elec Schematic
Chris2275FS
I have a 2000 2275FS pontoon boat and I am looking for a parts manual and electrical wiring schematic for under the console. The wiring harness that runs the interment gauge cluster has the ground wire melted through out the harness. Found the issue but need to replace the harness. Hoping to buy a harness vs making one. Thank you in advance.
Check with Bennington, their phone number is 888 906 2628.
Have your Hull ID when you call.
Just a thought - Could you just use some heat shrink tubing to repair or maybe it is just time to replace the entire posted area given the age?
I thought about that, but the ground wire is discolored from heat and will most likely give me resistance that I done want. To be honest, I am still surprised that the boat didn't catch on fire. I think by not having things stuffing that space saved it.
