2010 20sli Nav light fuse location
mstonionis
Hello on the 2010 20sli is it an inline fuse ? All other switches work as they should except nav switch
Thank you all
Have you checked your breakers?
If you have them they are the small push button below each switch . Good Luck .
There are about 6 round black tabs at very base of instrument panel but not directly under switches
Is that what you mean ? Thanks
My 1st Bennington was a 2013 ,they may have changed the location between 2010 and 2013.
Yes, those small buttons are the ones.
Great news!!! Glad you are set and good to go now.
