Tooncrazy
My 2275 GCW has the SPS package. Are the figures indicated above in line with what is to be expected?
Thanks.
Thanks.
Why did the dealer put a 4 blade prop on my boat if a 3 blade is better?You have a 4-blade prop and that's what you'll get, a little less speed and RPM.
Probably because that is what he had...?Why did the dealer put a 4 blade prop on my boat if a 3 blade is better?
I bought a Mercury Spit Fire 4-blade prop a couple years ago when I had my 115. My top speed dropped about 5 MPH, but it put out noticeably more torque and speed when tubing (so under heavy load). Anyone that's got a 115 and is pulling tubes, I'd recommend you try a Spit Fire and see what you think. They are not very expensive. $150, plus or minus. And it can do double duty as an on-board spare prop.Why did the dealer put a 4 blade prop on my boat if a 3 blade is better?
Thanks for your comments. When I started this thread I was more interested in finding out if my boat was performing on a par with other boats like mine.This is just for Tooncrazy's memory banks for the future. Speeds on the S models are as unrelated to speeds on a G or R as an R is to a Q. And within the models, there are big differences too, based on furniture bars and accessories. All other factors held constant, there are a couple hundred pounds of extra metal between an S and a G. And weight through water is magnified 11x vs weight through air. If you are comparing top speed a, you really have too many variables in hulls, decks and equipment to make a worthwhile comparison. Just so you know.
