wannabe captain
- Messages
- 5
- Reaction score
- 0
Hi, Im Barry and I just signed up for this Forum. I've owned boats of various types since I was 16 years old, never very mechanically gifted, but able to spot problems fairly easy. Just not good at solving them. I just purchased my first Bennington tritoon model # 2275 RL a couple days ago. A elderly couple had just trailered the boat after hitting an object messing the aluminum prop up pretty good. I was at the ramp looking at another bennington when I heard them say they were going to sell it ASAP They purchased boat motor and trailer new in mid 2008, and to my surprise it only had 22 hours on it and in mint condition, other than the prop. The motor being a 2008 model as well is a Yamaha 150 Four Stroke, fuel injected. Since the prop was beat up so bad, I didn't even take it for a spin before i bought it. The couple were not the boating kind, and just wanted to dump it. After getting the financial part of it completed, I brought it home to clean the toons and get a new prop before my maiden voyage.
First problem getting the toons cleaned. They said only left the boat in a slip for a couple months, but "MY GOSH" I put aluminum bright and after setting for a short time washed it off with my power washer and if didn't seem to faze it. Called a local marina and told me about Super Chief AB-50 and tried that spraying it from a gallon sprayer mixing from a few ounces as they suggested up to 50/50 mixture. The stronger worked better and all the algae and funk is off for the most part, but stains in some areas just aint budged. The man told me that I bought it from he had found some product called "SHARK SKIN" and applied it last year,
Second problem came from getting a aluminum 15" prop from a prop shop to use till he could fix the two damaged ones that came with the boat. When I installed the prop and launched the boat it was cavatating at all speeds, I had family with me so I babied it around till we got ready to come in for the day. When it would hold, top speed was about 23 mph at WOT and 6 grand on tach.
Today, the man who runs the prop shop locally, ends up being a neighbor of mine and he took my old one to the shop after Church, and straightened it best he could and brought back to me this afternoon.
Put the repaired prop on, loaded up more family that came in to try the new ride out and finally it held and got up to about 33 mph at 6g's with trimming a bit, and i mean very little bit. Prop would still cavatate some but im sure the right style and pitch in stainless steel would help solve that problem. Im hoping some of you have had similar situations and know the best type prop and pitch for tubing, skiing and site seeing.
Third problem (I Think), the motor is mounted in the next to last hole in transom for its lowest position. Im hoping some of you that know a whole lot more than me can tell me if lowering to its lowest position on the transom will allow me to trim the motor some and maybe help on performance. The couple told me the boat would run in the low 40's WOT, with 6 people and a couple of kids. I hope that the right prop and lowering motor may help with th e performance.
Last problem, so far since I've had it two days now. Trailering boat this afternoon, my spotter who was trying to make sure boat was between guides and on straight, miss judged and pontoon on the driver side ended up on the top of the guide and bent the metal rail and busted the guide board screws out. "I HOPE YALL ARE STILL WITH ME HERE AND NOT LAUGHING YOUR BUTTS OFF AT ME" I STILL NEED SOME HELP HERE. LOL.
The inside guides were spaced about four inches from the inner pontoon, and im thinking they need to be closer, if not touching while the boat is on the trailer.
Sorry for the novel here, but im a simple minded guy and just went through the chain of events on my newest pleasure craft.
Any and all help and suggestions will be greatly appreciated;
THANKS
BARRY
THANKS
BARRY
