FIRE UP
- Messages
- 223
- Reaction score
- 403
Gang,
I asked about this sometime last year but, didn't really get any answers I was looking for. After quite a bit of looking around, I finally found one that was near us in a local Bass and tackle shop. Well, it didn't work, wrong dimensions. So, I decided to simply make one. I purchased a 1" x 12" x 18" HDPE cutting board from Amazon for about $16 or so. I basically remembered the shape of the one I purchased but took back several months ago and, cut out two of them in the shape I thought I needed. I used a table saw to cut the basic blocks out then, I used a band saw to cut the details. I was originally going to make it double thickness from end to end and side to side. But, about 1/4 into the build, I found I couldn't make it double thickness where it would contact the motor steering pivot bracket.
But, I could have it double thickness at its base. So, I cut one off a few inches short. Then, I lined them up and screwed the two halves together with some stainless 10-24 x 2" screws. Once it was all together and edges all sanded and prepped, I laid out the lines for the critical drilling of the 3/4" holes needed for the power tilt rams to enter into. The way this unit is designed, those power tilt rams need to go all the way through the support so that the support rests on the bases of the power tilt rams and the rams do no supporting of the motor what so ever.
The rams themselves are measured very close to just a couple of thousandths over 11/16". I figured a 3/4" drilled hole, will do. But, those holes must be as close to precise as possible because, the clearance for the rams is very, very little. Then, those rams are parallel for at least 4" or more. I don't have the proper milling and drilling equipment for this kind of precise work. So, all of it must be done by hand and my old eyes. I used a 3/4" Forstner bit to drill those holes. That way I had better control. It took a bit of patience but, I got both holes drilled relatively parallel, how about that!!!!! Then, I checked for fit and, imagine that, IT WORKS. It supports that F-350 350 Yamaha V-8 rather nicely without putting a load on any hydraulic parts.
Once it was all checked out and made sure there was no fitment issues, I simply used a hand held deburring tool to round over all the edges and make it nicer to handle. Anyway, see what you think. I know that some of you really don't have any issue trailering your Benny's with that large of a motor either sitting against the power trim rams or, all the down since the prop is still pretty high off the ground, even with the motor in the fully lowered position. But, we have some angled streets around here that can present an *angle of departure* situation that makes that prop come dangerously close to the ground. And, tilting the motor up, now puts a shock load on all the components that are used for tilting the motor, when your running on rough, un-even roads, concrete seams and all that. So, this is why I did what I did.
Scott
Scott
