Is it a rocker style or push button? I had a push button style one go bad and it was simple to swap out. Inside the helm I removed the backer board or whatever you want to call it. Unscrewed the wiring harness retainer nut from the appropriate switch. Then pulled the connector off. Then I was able to unscrew the switch mounting locknut and pop it out.
I was also wondering if there is simply a loose connection under the helm leading to the switch given the description of how it’s going in and out. Maybe on and off contact with motion…?
