Access to Engine-Inboard
Larry Gerek
Hi, has anyone removed the engine cover that raises for access to the inboard? I need to replace oil sender on my 377mag, but I can’t seem to get to it. Heck, I’m not even sure I can find it!
Sacandaga Lake, NY
Big Kahuna had a Benny with an inboard if he doesn’t see this and respond send him a PM
Remediation
If you disconnect the actuator, you can raise the lid to vertical. Just make sure you remove the ski pylon so you don't dent the trim on the hatch.
BigKahuna
North Carolina
My whole changing room above the engine pod tilted back towards the stern like Remediation said. (Yes remove the ski pylon or it won't tilt all the way back) Once you do this you have full access to the engine pod!
Larry Gerek
I wish I had read your response first. I disconnected one of the shock absorbers….what a pain reconnecting!
