The RGB wires on the KMC100 are an input. If you connect to your RGB light controller then the outer “ring” around the KMC100 will illuminate.
You can also use the light without a controller. The black wire is positive input then a ground to the other wires will illuminate the color of the wire. Example, black to power and ground to red will illuminate red.
