All Accessory Switches Dead?
StilesYYZ
Hi everyone,
Definitely not an electrician here, but looking for tips on troubleshooting an issue.
Dual batteries are hooked up and confirmed to be charged. Motor can start. Master control switch (green light) lights up as normal, hour count gauge and fuel gauge and direction reading are showing (digital displays).
Downstream from that, none of the accessories on the dash work (horn, lights, bilge pump, radio, fish finder, etc).
I don't have a wiring plan for the boat (2012 2575 QCW)... Any tips on where to begin for troubleshooting?
Thanks in advance!
check for a small red wire that did not get hooked up to the batteries.
Check under your helm for loose wires/connectors on your switches .. I had a connector that I ended up putting a zip tie on . Also check your breakers .
Negative connection between batteries might be another item worth checking out if the above doesn’t solve it. Ask me how I know. :rolleyes: :D
