Anchor light for Bimini rail
timjet
I broke the fitting on my anchor light. The rod type light connected to the bimini with 2 screws is so long that when the bimini is lower it hits the back sofa rail. If I'm not careful just the weight of the bimini on the anchor light will break the adjustment fitting which it did. So I'm in search of a light that's shorter and perhaps that I can rotate when the bimini goes up and down. The current one mounts to the bimini with 2 screws. Most anchor lights I see on Amazon have a 4 screw pad that the light is attached to.
Any suggestions?
