Anchors
Jonbrowar16
I am struggling with anchors. I have an SX22 Bennington Tri Toon. I a, currently using 2 20lb Navy anchors. In many cases they do not hold the boat. Can someone please tell me what is the best and most effective anchor to use.
Thank you
Jon
I use a slide box anchor. But they can be difficult to pull up on a sand bottom . Amazon has some in ,3 sizes
Thank you
Jon
What type of bottom? Water depth? Inland lake or ocean?
It's a state lake, lots of mud, 25-35ft of water
Ok...how do you set the anchor? Do you just drop it over the side or do you lay out sufficient anchor line (rode) and set the anchor?
For a depth of 30' you need a scope (anchor line length) of 150 feet (5:1).
I'm not sure what a Navy anchor is but for a mud bottom you probably want a fluke anchor.
1778681410174.pngThis is a navy anchor. I do have 100" of anchor rope and yes I have just been dropping off the side
You could add 3 feet of chain to that anchor before the rope begins to help lay it down. And at least 3:1 or more rope to depth.
Search bar! Probably many threads on this over the years, the good news is there are way better options than a "navy" anchor which doesn't appear to be suited for your type of boating. I have one that will dig in so deep you'll pull your back out trying to pop it off bottom!
An anchor should not be judged solely on its holding power. Typically the strongest holding anchor has sharp steel plates and a heavy chain. Most of the time I do not want to bring this type of anchor on my fragile aluminum boat. Anchors with pivot points can trap mud and weeds. Cleaning the anchor is tough when on a relatively tall pontoon boat. Despite all this there are rare occasions that a strong holding anchor is needed. For those rare occasions I have an anchor that I leave on the ground down by the lake. The last time I used it was 5 years ago during fireworks on a windy fourth of July. My main anchor that I keep on on the boat is rubber covered. I have thought about using a bowling ball on the thick soft line but that would be going too far.
The above quote is from another related thread. It goes without saying that the “best and most effective anchor” is not always the same.
The Eternal Debate - I have 2 original Slide Anchors (well, actually about my 4th set - I tend to lose one per year). I carry a Small (19lbs) and Large (26 lbs) - so no wind, some wind, very windy - no issues, my 26' with Double Bimini does not move. The Original Box Ancher by Slide Anchor are better - I tried two other brands - the hinges and especially the pin lock simply did not function as well. No chain needed. AND, get yourself a canvas wood tote to hold them - it makes getting them in and out to the front and/or back SO MUCH EASIER. I fit both under one of the seats. https://www.slideanchor.com/box-anchor-/box-anchor-wg4na
