B&b Blades Prop Project
CcanDo
Earlier I explained Collaberation with B&B Blades to find a solution for using a Mercury or B&B Blades Prop on the Yamaha 350.
Solas Props has responded with the required prop hub kit part number needed to order.
We'll get the kit and start testing .
Merc makes the prop kits for other than Merc motors. I had to get one to use the Enertia on our Honda.
Sounds interesting, has B Blades worked with Tri toon props before?
I never specifically asked Brett about all triple tube applications. However, he is easy to talk with, and interested in offering pontoon support.
