kaydano
- Messages
- 4,310
- Reaction score
- 2,213
Which wire on the positive terminal of the battery is the charging current from the alternator coming from? Does it share the same wire that goes from the battery to the starter (the large #4 gauge wire) or does the charging current return from the alternator to the battery via the smaller wire (#10 or so, not sure)?
I'm pretty sure the charging current returns to the battery via the large conductor, but I'm thinking about installing a second battery and an isolator and many online wiring diagrams show a separate cable coming back to the battery from the alternator (separate from the starting cable). My battery only has two cables attached to the positive terminal (also two to the negative too, with one being much smaller than the other).
I also assume the smaller wire runs everything else on the boat (lights, CD, depth, etc). Is this correct? Anyone know?
