Bennington Logo
Oldeck
Manistee Lake Kalkaska, MI
Does anyone have the Bennington logo and text in a dxf or jpg file? I am trying to 3D print a few things for my pontoon and want to incorporate the log and/or name into the design.
Does this help?
I stumbled across this. Don't know if it helps or you have already done what you were going to do.
That is awesome!
That is very sharp!
Bimini rail cover? When it's opened or closed???
I have to put the bimini all the way down to get under a very low bridge/tunnel, with not much room on either side. The rails in the fully down position can still hit the sides of the tunnel if you are not careful. This is why I made these. It's definitely a special case just for me. With over a foot of ice on the lake, it will be a long time before I can test these out :( I will post a picture in the Spring.
Tight squeeze for sure! A+ on creating a solution to the problem.
I understand now.......Thanks.
Lake Gaston on the Virginia/NC line had a bunch of tunnels like that in order to get to some parts of the lake. We had a bowrider at the time and we were a nervous wreck!
Just better hope the wind is not blowing too hard. Yikes!
I am 6' and can stand up going through, if you are 6'2", you would bump your head:)
I'm 6'5" so I'd be getting more than a bump....more like scalped!
