Bimini mounted stern light on a 2018 bennington SSX22
Hi....have an older Benny Tritoon and the stern light won't stay up. Think the previous owner flew a flag from it and stripped the bracket tension or broke the teeth. Dealer says they have a replacment bracket $35 and a new LED light pole for $99. Can you suggest anything that I can buy online that would work and not require new drilling etc. on the bimini? Current is original to the boat (2008 rl24) and thinking changing out to an LED model. Any suggestions or do you recommend just getting from the dealer. Evidently, they were made for Bennington by Perko, and also reading the break easily. Thanks, Terry, St. Louis, MO
Had my base replaced twice under warranty.
I replaced mine twice under warranty and then got tired of that and replaced it with one of these. I remove the post and light and store it in the door pocket and just put it back on if I’m out after sunset, only the base stays in place. This light has a plug at the base so it’s simple and quick to re attach.
