Bimini nav light connectors. Unable to find ones that fit. I have a 2020 188 slv
Bigdaveb63
I’ve bought a kit off Amazon that had several sizes.went to Menards,Lowe’s unable to locate. Need help
Can you post a picture of what you are looking to connect?
Might be worth trying Grainger Industrial Supply or West Marine.
Here is what the look like
They look like insulated bullet connectors, make your own with heat shrink tubing..
I threw a set of calipers on the bullet connecters for the Bennington wire connectors to our tops it is 0.175" (4.44 mm) diameter. So the part number is 16-14 .175 male bullet connector, now you'll have to shop for the amount of insulation you'll need. Now at least you have something to google. Good luck!
