Do you know where these pumps discharge?On my 2015 2575 RSD, there are two. One is in the back, under the fuel tank. I think it is accessed from the rear flip-up upholstered bench top, where the engine batteries are located. The second is as described above, under the composite board in the center toon storage.
I'm not sure. The only time I ran them was after a big wave at Lake Powell that put water in the center storage. Since we were in the water, I couldn't tell. Next time I'm under the boat I'll see if I can tell where the tubing is routed.Do you know where these pumps discharge?
On my 2017 23RSB, the discharge is into the transom on the port side.Do you know where these pumps discharge?
This is where mine discharges as well. 2017 SSBXPOn my 2017 23RSB, the discharge is into the transom on the port side.
