keithkz
My owner's manual says that to change the oil in my Volvo Penta engine I simply have to remove the dipstick and then the top of where the dipstick came out of is an adapter so you can use a manual or electric oil pump "from any marina" in order to suck the oil out of the engine rather than drain it from the bottom. So it's actually designed to be drained this way. Well I don't know what pump they're talking about but I certainly cannot use the one I just bought to change the outdrive lube. Does anyone know what exactly needs to be used to connect to this so I can drain the oil out????
