Cooler
I have had different models they all had a built in under seat cooler. Bow Starboard seat.
Mine didn’t come with one when I bought it so I purchased it and am going to install but was curious how the factory setup looked or even someone’s self install setup. Little nervous to drill a big hole in my boat
What year and model do you have ?
Check with your dealer , they may be able to order one from a comparable model that would fit . As far as drilling ,you might not have to . Mine had/has a drain line similar to the cup holder drain lines .
Here are the pictures that I have - ideally they will help some. I pulled mine out - not enough insulation for my 110 degree plus heat, I needed more storage (the mooring cover fits perfect in this spot), and you can't get in and out of these corner compartments with the filler seat, which we have.
2021-07-05 11.56.42 Seat Cooler.jpgddd2021-07-05 18.49.39 Seat Cooler.jpg2021-07-05 18.48.52 Seat Cooler.jpg2021-07-05 16.53.45 Seat Cooler.jpg2021-07-05 11.53.54 Seat Cooler.jpg2021-07-05 11.56.37 Seat Cooler.jpg2021-07-05 11.53.16 Seat Cooler.jpg
View attachment 34251dddView attachment 34254View attachment 34253View attachment 34252View attachment 34256View attachment 34257View attachment 34255
Good idea to take it out. We also never use it and it would be nice to have the storage. Did you end up plugging the hole in the bottom?
Yes, found a large rubber stopper on amazon. the hole being upfront does not have much, if any, water exposure.
