Cover already has a tear--repair?
Bill Watson
My second post of the day. I'm on a roll. Thank you for tolerating my lack of proper terminology. The son of a son of a sailor I am not.
My tritoon is only one year old. Yesterday I discovered a small tear in the top (stern port side at corner of side rails). This spot is definitely a high stress spot since it rubs the corner of the railing. I assume this is common.
Two questions:
1. What's the best way to repair this small tear (probably only 2 inches)?
2. What's the best method to prevent this from happening again? Is there a good way to loosen the top to decrease friction at the pressure points?
Thank you for your help!
If it's only 1 year old check with your dealer on both items .
Depending how it occurred both issue may be covered under warranty
