I have a Bennington that has the bed in the rear and one of the cushions that covers the battery box is loose. It’s held in place by rubber fastener and I think because of the battery acid it has weakened these fasteners the problem I’m having is I don’t know what the name of these are to order replacement. Does anyone know the name it’s the cushion over the battery box.
Every model of Benntington has the batteries under different cushions / locations. I suggest year, model and pictures would help. With the pictures, any dealer should be able to help (you will have to order though them). I assume from your description you have a SB - I found this in my library, but did not have a picutre of the cushion insert.
Further, you should have AGM batteries that are sealed, and thus the battery acid would not be an issue.
