My dealer just replaced my trim/voltage gauge on my 2020 G Series pontoon. The trim display works the opposite from the direction of movement. If you are lowering the engine the trim display shows it rising, when raising the engine the gauge shows it lowering. Seems like the wires are just reversed on the gauge. Do these gauges just pull/pop out allowing me to reverse the wires or must it be accessed from inside the console? My dealer will come out, but would not be able to until after Memorial Day. I truly believe the two wires have been installed in reverse and should be a very easy repair. Please advise how I access the rear of this gauge. Thank You!
