Dead Accessory panel
mickheff73
2018 Bennington SSRXP
I was wiring up my new chartplotter and saw 2 disconnected molex connectors. Not so smart me decided to plug them in as they looked to be the same size and 1 was male., other was female. It very quickly got hot and I disconnected immediately. (I'm thinking they were the unused bimini and RGB connections) after looking at generic diagrams.
Now all of the dash switches are inop. (AUX, Livewell, Lights, Nav/Anchor)
I checked all the CB pushbuttons, they are all sort of loose, as in they arent popped out, but there is no feedback if I push them back in.
I cant find any fuses near the batter as I would expect to find on other boats.
Is there a master 30A fuse somewhere , my battery has a green wire coming off the negative terminal running into the wire bundle, but I cant trace it into the console.
Any suggestions, I will get the multimeter out tomorrow to see if there is power to the dash. The engine and ignition, fuel, trim, RPM, and hours gage all work fine.
Thanks
Edit -
Found the 30A fuse coming from the + of the battery bank cutoff. Old owner had electrical tape around it....reset easily.
Thanks
Edit -
Did that fix your problem?
