Looking at a 22 foot M series with the extended aft deck. Our dock slip is 9 ft wide. I know this is going to be tight. Our current boat is a Monterey Bowrider with an 8ft 3 inch beam. I have had no major issues docking it. Fortunately not one of the more heavy traffic lakes. We also have a pier extension on one side of the slip which will help. Can pull the boat up to it and ease it in. Not something I have to do with the Monterey, I just glide in, but I know docking a boxy tritoon will benefit from this.
I know a wider slip would be better, obviously, but may be difficult to impossible. Have seen posts about this, mostly with comments from people who have 10 ft wide slips advising. Have seen a couple of posts from people with 9 ft slips saying it works. Hoping to hear from others in this situation.
I will definitely upgrade dock
If they could shift the support beams so they are not jutting out into the slip space, would buy me an extra 9 inches. Not sure how viable that is, putting new pilings next to where holes habe already been dug. Anything more than that might get shot down by Duke Energy, who we lease our Lake front from. So I have to buy with the idea that the slip is unlikely to change.
Bunks: the aft side cross beam sits 19 ft back from the front of the slip. Dealer thinks 12 ft bunk boards would be fine. If I center a 12 ft board between beams, that has the bunk board extending 1.5 feet forward and after, so the back edge goes to a little over the 21ft point on the tube. Is that adequate or should I go for 14 ft? He pointed out that many trailers only have 6 ft bunks, so 12 should be fine.
Right as I was about to post this, the dock contractor that I had asked about refitting my lift suggested this conversion kit that provides deck support. Any thoughts on this? Everything I have seen has been mostly support for the tubes and from what I read briefly, that seems to be the preferred option as opposed to deck support
If they could shift the support beams so they are not jutting out into the slip space, would buy me an extra 9 inches. Not sure how viable that is, putting new pilings next to where holes habe already been dug. Anything more than that might get shot down by Duke Energy, who we lease our Lake front from. So I have to buy with the idea that the slip is unlikely to change.Bunks: the aft side cross beam sits 19 ft back from the front of the slip. Dealer thinks 12 ft bunk boards would be fine. If I center a 12 ft board between beams, that has the bunk board extending 1.5 feet forward and after, so the back edge goes to a little over the 21ft point on the tube. Is that adequate or should I go for 14 ft? He pointed out that many trailers only have 6 ft bunks, so 12 should be fine.
