Electric Anchor Problem
yuxoti
Hello.
How do I change the fuse for the anchor switch on a 2018 21SLX?
The anchor switch doesn't light up. The accessories and lights switches next to it light up. I've pushed the reset buttons below the switch and on the anchor box with no results. I can see underneath the console it is a 5 amp fuse. I tried pulling that wiring black piece out but not sure how hard I should try! Not sure where the fuse is located. Thanks for any help.
Michiman
Okemos, MI
If I understand your problem correctly, the anchor light switch works, but doesn’t light up like the rest of the switches. If that’s the case, I’d say you need a new switch, which should be covered under warranty.
CLDave
