Fuse Panel 2021 20SVL
tyrbrenner
First, thank you for your time. Last week I discoverd my 2021 20SVL pontoon had a dead battery…let friend use it. I charged the battery and took the boat out today. Boats running great. Unfortunately, the MPH, hours, fuels and tilt gages are no longer working. Does anyone know where the fuse (or other problem) could be. I’ve been under the console and only see one in-line fuse that appears to be ok. I also don’t see the one breaker by the battery tripped…nothing appear ant to me. I appreciate any insight you might have.
Have you checked your breakers?
Yes. I was asking about the breakers on your helm . Have you traced the power from the battery to your helm ? It could be an issue that your dealer needs to look at.
Thank you for the help. I’m going to beat my head against the helm a few more times before I drag it out of the water to the dealer.
Did you remove battery to charge? If so make sure you didn’t miss hooking up a ground. Sounds more like a common ground problem if multiple gauges are not working.
