I found some unused factory wiring.
entremanure
The Ozarks
I have a new to me 2000 207L and found some unused wires while upgrading to LED docking lights. The two wires (one white, one green) have pink crimp on terminals and are located under the deck directly below the docking lights. Anyone know what these are? Are they switched? Thanks in advance for your help.
Just might be for a live well that will "usually" be in a front compartment.
Some of the older boats had the horn under the front
My '06 had two sets of unused wires that terminated below deck at the bow. One set was for additional speakers and were already wired into the stereo. The other set is for additional interior task lights and are already hooked to one of the rocker switches. I found the bow corner boxes were pre-drilled for both options so adding either option was as simple as cutting away the vinyl covering the holes and popping them in.
