Thanks so much. Also need a part number if available. I'll call tomorrow. JimIf no one here can help you can contact Bennington. I don't have access to their phone # right now, but you can do a search in the upper right corner. If you call have your Hull ID .
Thanks Jack. I'm getting closer.You're Welcome .Here is the number ,888 906 2628
Gave me a local marina source, and follow up and get the needed part. Thanks.Were they able to get what you needed?
One thing now i may need is a color coding chart for wire placement. I can probably just look at the old contact placements while disconnecting and mark as i go. Since it's old and the original part isn't made anymore, thought this might help.Good Luck ,let us know the outcome .
Update. Got the correct key ignition switch and got it all hooked and good to go. Thanks for your help Jack. JimOne thing now i may need is a color coding chart for wire placement. I can probably just look at the old contact placements while disconnecting and mark as i go. Since it's old and the original part isn't made anymore, thought this might help.
