ISO Rocker Switch Covers HORIZONTAL
adventureawaits
Hey Everyone, I did a search in the forum and came up empty. We bought a 2018 ssbxp and i want to replace most of the rocker switch covers (also called actuators?) but most everything i'm seeing are the vertical rocker switches. 6 of mine are horizontal. the way the dash is designed, i can't turn them to vertical. the only solution i've seen are custom switch covers which are double $ what the others are. i just need some standard text (horn, dock lite, nav lite, etc). while i do want a few custom made (replacing ACC switches with stereo, garmin, etc.) i would prefer only having to make 2 or 3 custom switches.
does anyone have a lead on horizontal oriented switch covers? i could also buy the vertical ones and install them sideways but a swanky boat deserves correctly-oriented text on rocker switches ;) thank you!
I replaced all my rocker switch covers on my last boat. (Look at post #3 in this thread for before and after shots. Switch Layout 2011 22SFI).
I used New Wire marine and I am a very satisfied customer. They know everything about rocker switches and can supply just about anything you need. New Wire Marine. It takes seconds to swap the cover on a rocker switch if you use their $5 plastic cover removal tool.
I was just coming to say the same thing. They are nice.
You set up looks good BTW!
