Glava2876
- Messages
- 42
- Reaction score
- 70
I should have gone through this sooner, but we bought our place last October and were focused on the indoor projects.
Now I can zoom in on the outdoors!
First priority -my lift is installed and I am at this point now:
1) There is a GFI outlet on the post on the dock, it is a dedicated line from the electrical panel.
2) Along the plastic conduit under my outdoor deck is a weatherproof on/ off switch.
3) The 110V Lift cord is near the end of the dock, about a 40' run.
What I am thinking of doing is as follows:
When I pull the lift for the winter, I'll leave it off and pull the extension cord.
See the pictures -does this sound like a good way to do this, and /or, please give me comments on what I may want to do differently.
Thanks!
The lift has a remote and bluetooth capable
Looking back, the outlet is on the post at the top of the picture
Figured to run the PVC on the top edge of the dock?
The on/ of switch for the outlet is under the left side of the deck.
This is before the lift was installed, when the water was lower than the norm, but you can see the conduit along the side of the dock, running to the post on this side.
- Run PVC pipe on the edge of the dock, from the outlet, to the end near the lift.
- The lift end will be left open.
- The outlet end to come up the pole, and turn back down towards the dock .
- Then I want to slide an HD 12 gauge weather proof cord inside the PVC.
Thanks!
