Live well repair
Rssuttle
I need to remove the black panel on the back of the live well. Looks simple enough. About a dozen screws. I think the pylon needs to come out and I see only one bolt holding it. Has anyone removed the panel and pylon?? The gas tank and live well are behind panel.
Also: Is there a repair / service manual for Bennington that shows schematics.
thanks.
black panel is the picture attached
I have a 2011 GCW with the stainless steel pylon. My set up looks different than yours. But to remove my pylon, you have to turn it CLOCKWISE about 30 degrees and pull up.
Hey. Just and update. The pylon comes out the on the newer model as yours. Was simple to remove. Even pulling the black plastic cover was easy except they’re is what I believe is a gas vent attached to the black plastic cover. I did not have the correct tools so I had to put it back together until I do.
