I have a 2018 21SL pontoon (25" tubes and no lifting strakes) with a Yamaha F115 HP outboard (max for this toon). The outboard came standard with a 13.5 x 15 AL prop. I purchased this boat new and I have over 123 hours on it. I am looking to upgrade both midrange performance (when tubing and cruising with heavy loads) and improved fuel economy. I used to have a fishing boat and loved the 4 blade SS prop I had on it but unsure of real world performance on a pontoon. The Yamaha prop selector is of little use and it seems there are as many opinions as ... but looking for real experiences of either a 3 or 4 blade SS prop on a pontoon with similar size and with a Yamaha F90 or F115 as both use the same block.
Specs for the engine: Full throttle range 5300-6300 RPM
Specs of this boat with a light load: WOT 6200 RMPs (suggests a higher pitch but would reduce low end performance), holds plane at 3500-3600 RPMs and tops out at 31 MPH.
The boat is used for everything from large group cruising, pulling tubes and fishing. I am will to give up a little on the top end but not more than 2 MPH as I am on a large lake.
Has anyone upgraded to a 3 or 4 blade stainless steel prop with a similar boat/motor configuration and if so which one?
Thanks
Thanks
