MercMonitor Gauges
CrackerJack
Prescott, AZ
For those of you who haven't seen the MercMonitor gauges here is a picture installed on my pontoon.  Fairly easy conversion and allows for much more information to be displayed.
TomS has them and loves them from what I've heard.
were they factory mounted or did you add them after the the fact?  What motor do you have?  Do you have part numbers if you put them on after the fact?
I'd love a set of these for my Pro 150XS opti. Just not sure which gauges to order nor if there is a harness upgrade or not?
thanks
Todd
Sorry for the reply being so delayed.
I replaced the factory Mercury SC100 gauges with the MercMonitor digital ones.  Nearly plug and play. No modification to the dash is required.  There is a nest of wires under the dash and you have to cut some Zip ties to unravel the mess, but once you follow each wire bundle it becomes obvious what plugs into what.
I have the I/O Mercury V8.
I would just contact a Mercury dealer and ask if the gauges are compatible and if any adaptors would be required.
