MOORING WHIPS
Before I had a lift I used mooring whips for years, never had a problem, they are quick and easy once you get your ropes tied and looped at the proper lengths.
Steve
The only down side is in bad blow the whips can break and there is no protection for the boat.  I thought about using them in Canada but we can get some big storms that last all day and was not comfortable depending on them.  I created a docking system that is much stronger but not as easy to use.
I just used whips rated for 8,000lbs boat on a pontoon, put a aluminum back plate under the decking. Never had a problem, I get wake board boats 50 feet off my dock all summer long, hard to even stand on the floating portion.
Steve
I used them on my 24SSL. Wonderful invention. Kept the boat off the dock in all but highest wind conditions. I always had mooring lines attached to the dock as well, and if there was a big blow coming I just added a couple of fenders on the dock. No problems.
If a big storm was coming, would it help to throw a couple anchors off the non-dock side?
You can see above mine was moored a good five feet off the dock, it never came close (like 3.5 feet) to touching the dock even in 30 to 40mph winds. As I posted above buy a heavier pair of whips than recommended.
Steve
These seem like they would be great for a permanent dock where ice isn't an issue. The end of my removable dock is on poles that are almost 6 feet off the bottom of the lake. Too much sway for using mooring whips I would think.
Can't say about ice, that we in SC know nothing about. My floating portion is in a minimum of side feet in depth, when the water is up I'm at 10+ feet in depth. One pole on each corner of the floater, they are permanent.
Steve
