Morning cover Pole feet
MrG
Lake Tulloch Ca
I’m looking to replace the Rubber Feet that go on the ends of the Adjustable poles that support your cover here is a photo of what I’m looking for
Go to a big box store and look for furniture hardware. Felt pad area will have those cups. I bought a set 2 weeks ago to cover the end of a support pole I installed for my FIL
Cane/crutch end cap
All of the above ideas should get you what you need.
I got the cane/crutch end caps 3/4 end size they are 2x as thick and solid as the factory pole ends are. They are super tight to put on and that’s a good thing. Hopefully they won’t pop off like the factory ones do.
Here is a link to the ones I got. Thanks for the suggestion.
DMI Walker and Cane Tips with Metal Inserts, ¾ Inch, Black, 2 Count (Pack of 1)
https://a.co/d/daC8jNG
Ok would I be pushing my luck asking for a source on some new adjuster lever’s I have 2 broken ones :) here is 1 broken one and 1 good one (on the right)
I orderd 2 of them I’ll let ya know how they work out
Thanks. I have 2 that need replacing. If these work for you, I’ll order a pair myself.
If they work I’ll let the group know and I’m pretty sure I’ll get 3 more. I noticed that all the levers are pretty distorted at the hinge point so the others are most likely on their way
This is how mine are too. Workable, but not optimal anymore.
Hey great News the New pole adjusters are an exact match and fit thanks for the links in this thread. Just be aware it uses a T-15 star wrench NOT a Allen key
On another Side note. The temps that your boat reaches while under the cover are crazy. I’m sure the elevated temps under the cover accelerate the breakdown in all the materials vinyl, rubber, plastic, the Poles that hold up the cover are so HOT you can’t even hold them I’m sure that helps warp the plastic on the poles.
