Nav lights and Horn
TStack
I have a 2019 Bennington. The starboard Nav light does not work. I unscrewed light base to check light, but unable to raise more than 1/2" above deck apparently due to wire short length. Suggestions?
Also, horn not working. Any thoughts?
Thanks
The horn and nav lights don’t share a circuit. So I believe you have 2 separate issues,if everything else electrical is working. Your best bet is to take it to the dealer as it’s under warranty. That said, To get the nav light apart you have to take the whole housing apart. check if you have 12 volts at the connector under the deck, before taking it apart. If you don’t have 12 volts there, take it to the dealer, there’s a problem in the wiring. If you do have 12 volts, the fixture needs to be taken apart to see if your getting 12 volts there. Could be a loose connection, corroded connection, broken wire or just a bad fixture or bulb. (Mine was a loose and corroded bulb contact. After all that, I had to replace it a year later, same issue) As far as the horn goes, check the circuit breaker, check to see that you have 12 volts at the switch and if you do, if you get 12 volts at the horn when you push the switch. Depending on what you find, could be a bad horn, bad ground, loose connection, broken wire or something else. So, like I said, take it to the dealer and let them chase all that down.
Hope that helps.
I am thinking the dealer too since it’s fairly new and under warranty. Seems like two minor issues. However, it may involve some trial and error to track down the problems. I’d let the dealer spend their time doing that (if convenient). If you have spare time on your hands, and like to DIY, then maybe messing with the dealer isn’t worth it.
