Navigation light replacement
timjet
I had to replace the port pontoon on my Bene 6 months ago. I just noticed the port red navigation light is not working. I don't know if during the pontoon replacement the wiring to the port light was damaged or even if the wiring to the light goes anywhere near the pontoon. I can't see how to open the housing to the light to check it. Any help with this is appreciated.
Hummmm, well there is a multitude of different nav lights. That said, both the original and the upgrade LED replacements on our pontoon are held in place by under deck screws/bolts. No mounting hardware shows topside. You may find some small nuts/wing nuts on machine screws or some other, more sophisticated mounts. The wiring for ours is obvious and easy to check for power.
