Push Pole Type Shallow Water Anchors?
GarySWI
I searched the archives and didn't find anything recent. I'm not looking at folding PowerPole anchors.
We typically anchor over a sand bottom in 3-4 feet of water on a sand bar.
I was looking at MaxGain Systems poles which come in either 3/4" or 1" diameter. They have fixed lengths or screw together poles that would be easier to store.
What I'm looking for is some type of mount. I'm thinking something for the stern vs a bow mount because we use the bow deck a lot and I'd like to avoid having anything that could become a trip hazard.
I have seen mounts that attach to the motor mounting bolts. That might be ideal if the clearances work out. Unfortunately my boats in winter storage so I can't look at that for several months.
Any thoughts or suggestions?
I used this product in the past with another boat.
Multiple mount options. Push comes to shove just tie dockline around it and cleat it when on the bar.
Multiple mount options. Put comes to shove just tie dockline around it and cleat it when on the bar.
Thank you very much. Just the information I was looking for.
I drilled a hole through the front corner area of my front decking then screwed a pipe flange down with a 1" x 4" pipe on it. Works perfect.
