I could swear...when I first got my boat, I could leave the water system powered on and the pump would only run when I turned on a faucet. When the faucet turned off, the system would shut off automatically.
If that's true, then there's a pressure switch on the pump that activates +12v only when pressure drops.
Last year, what I am remembering, stopped happening. When I would power the system on, the pump would run the whole time regardless if a faucet was open or not. To me, that meant that either there was an air leak in the system, or the pressure switch went bad.
Took it to the dealer to be fixed, and they are telling me there is not a pressure switch on that system that they know of. And that when the system is powered on, it will run the pump.
The dealer may be exactly right, and I may be imagining that the pump would cycle on and off automatically based on an open faucet. Or maybe I'm right and the dealer is just unaware.
Can anyone with the pressure water system chime in with how their setup works?
-Jeff
-Jeff
