Mel Bodman
- Messages
- 1
- Reaction score
- 0
Is there any repair options for fixing shrink wrap that melted into the vinyl flooring on my 20 ‘ Bennington Pontoon boat? Any suggestions would be helpful.
Cut out a circle just large enough to cover the blemish. Place it over the blemish use as a guide to cut out the bad area.
This!Who did the shrink wrap? Sounds like something they need to cover.
But it really needs to be that way.It is amazing what is in some of the contracts around my area for winterization and storage. Some of the contracts have you essentially waving all rights and they are responsible for virtually nothing. That assumes they hold you to the contract when it is their fault. Reading the fine print can be scary.
A couple of years ago this happened where my boat is stored .One of my dealers storage building collapsed from the snow ,took out a lot of boats. I think ( I may be wrong since mine was not involved ) the dealers insurance covered the deductibles the owners insurance covered the balance. At the time of storage you must provide a copy of your insurance ,or you will be storing it else where.But it really needs to be that way.
Let's say you own a building and are storing 100 boats inside of it. What's the worse that can happen? Total loss of 100 boats and the structure, that's what could happen. Can you imagine the what the premiums would be if you wanted to take on that responsibility? You simply couldn't math that one out. Furthermore, all of the boat owners should already have coverage in place. So...
I understand not covering the risk, especially catastrophic loss. However, some of the language is so wide ranging that it exempts them of risk of their own doing. I have watched a kid pull my boat out and drag the skeg on the concrete ramp out of the garage. They lowered the motor to get more boats squeezed in and forgot to raise it when pulling it out. I have had some bad experiences. I walk around my boat and take a video before dropping it off so I have some proof that any damage wasn’t on my end. May not hold up, but at least I can try.But it really needs to be that way.
Nope…Just using a small portable generator. My understanding was no disconnect, just plugged into a power switch set up to bypass house fuse box and provide power directly to HVAC system when power was out. I’d be surprised if insurance doesn’t look to not cover it, but never heard anything further after the event.That is why you are " supposed " to have disconnect on a portable generator .Id be curious to hear if insurance covered things if he didnt have a disconnect. There is no way a disconnect can fail, its human controlled . Now if he had a full size whole house generator and the transfer switch failed ,that a different story .
I had a disconnect on my previous house . We've got a Generac with the correct transfer switch at this house .
