Running lights
Molasses
I have a 2005 2275rl in great condition.  Bought it used.  Have never changed the red running light.  Now it is out.  I see the 2 screws on the bulb casing.  I see the one screw that goes all the wat through with the nut or something on it.  How do you remove the nut...or rather, what tool is required.  Since the other screw does not have a nut to remove, will removing the one screw  give access to the bulb.  Thanks for the help.
Carl?!?
If you have the plastic housing with the docking lights and the navigation lights, you will have to remove the entire assembly to get to the bulbs in the red/green lights.
Thank you.  That is exactly what I needed to know.  Appreciate the quick response.
Also, is it impossible to find a replacement tachometer with hourmeter for my Bennington?  If I can is Fiara the best way to go?  Thanks again.  Learning a lot from other posts.
I have a 2009 2575rli that had a tach issue.I emailed bennington and they said it was built by Actia corp. in Elkhart, Indiana.I first tried purchasing a new one from a bennington dealer with no success.I then contacted Actia and they no longer had this unit, but said they do repairs.I shipped my tach to them and had it back within a week and a half.The cost with shipping was approx. $150.I thought this was a little pricey at 1st,but this was an expensive tach with the digital readout for trim, fuel,engine hours,etc.They did a great job,so overall,I was very pleased.You can contact bennington with your hull number,and they can tell you who made it,and if it's Actia, this is an option             Hope this helps
