Seams on Upholstery Coming Apart
SOPOPONTOON
My 2018 Pontoon's seams are coming apart in several locations on the seating. Has anyone else had this issue and did you dealer cover this under warranty? Thanks.
If you are the original owner it should be covered underwarranty ,as long as it is not sun damaged from not using your cover . Check with you dealer .
