Lakeliving asked for a thread about competition water skiing...so here it is.
For starters - a drawing of a competition course with measurements between buoys.
In its simplest form, it's just a course that includes boat guides, some entry and exit gates, and 6 balls that you have to ski around, in order without missing. Sounds easy enough? Yeah...no.
In this post, I'll give you the basics of the slalom course and what skiers do to make it a competitive sport.
In later posts, I'll tell you a bit about the boats, the equipment and the skis...which is pretty cool stuff in my opinion...especially since all I am anymore, is a driver.
On a ski boat, the ski rope is attached to pylon afixed to the floor at the approximate center of the boat. When the boat is tracking properly through the course, the distance from the pylon to the buoy ball is 38'.
Skiers can start with a line as long as 75'. And the speed of the boat is variable from 24.9mph to 36mph. Scoring is a combination of how many balls the skier completes and how fast the boat was going. Complete the course at 75' of rope and a particular boat speed, and the next step is to shorten the rope.
Slalom ropes have colored sections that are looped together to form the proper line lengths. The first drop is 15'. This is called 15-off. At this point, the rope is now 60' long. There's another drop at 22'. Cleverly called 22-off, the rope is 53 feet long. The shorter the rope the faster the skier has to move from one side of the course to the other because the pendulum is shorter. The geometry required to get through the course changes dramatically at each line-length-change.
As skiers advance, the line shortens like this.
15-off. Rope is 60' long.
22-off. Rope is 53' long.
28-off. Rope is 47' long.
32-off. Rope is 43' long.
35-off. Rope is 40' long.
38-off. Rope is 37' long.
39.5-off. Rope is 35.5' long.
41-off. Rope is 33' long.
43-off. Rope is 31' long.
And as skiers advance more...the boat speeds up. Scoring is heavily dependent on boat speed. Running 6 balls at 32 off and 32mph may get you more points than running 38 off at 30mph. Once you select a boat speed though, there's no going back. And most competitions have mins for boat speed, or constant boat speeds i.e. - the entire competition for men at 34.2mph and for women at 30.4mph.
Once the rope is set to 32-off or shorter, the skier has to swing almost perpendicular to the boat in order to clear the ball. No matter how short the rope gets...the ball is still 38' away. At 38-off, the rope is shorter than the distance between the tow pylon and the ball. The skier has to be perpendicular to the boat and use their height to get the ski around the ball.
Speeds across the lane can break 65mph very easily. And I've seen a skier complete the course at 36mph and 41-off...with the announcer claiming he was breaking 70mph across the lane. That's just insane to watch.
That's the basics. Scoring is simple. Speed first...in order to beat another skier who's skiing at 36mph...you have to ski at 36mph. After that...it's line length and ball count. "36mph, 3 balls at 41-off" might be a winner in a particular tournament.
Next up - the driver, the boats and the equipment. Just a heads-up...driving is way harder than it looks.
