LaurencetheAdventurer
Expanded:
With the new LifePo’s in, I am feeling confident that I now have enough power to up the performance of my Tunes. At this point, I am only looking to ad an amp and sub. Speakers – for another budget season….
Questions on adding an Amp/Sub:
Consensus Acknowledged: JL or WetSounds is the Best but pricey; Rockford Fosgate is solid; Kicker seems to have a higher failure rate, but most love the upgrade.
No Tower, Ski Pole – so tower speakers are not an option.
I have the stock Rockford Fosgate PMX2 with 6 RGB Kickers (2 on back of SB). No objections to the sound when floating or cruising at 20, but when we are going up the lake at 30+ – I clearly don’t have the power needed to hear the music. Extensive reading and research (26 pages) suggest that if I am not an audiophile, then just getting a quality amp may solve my issue, and adding a Subwoofer will definitely take me to a new level of sound quality. YAY!
The Sub: I concluded there are two types, Infinite Baffle (“free air” install sub speaker into a large sealed cavity – ha, my Benny is stuffed full) or an Enclosed Sub (Sealed/Loaded (pre-wired / powered) or Ported (bigger boom, but needs space). I don’t have much room – so Sealed/Loaded is the answer.
You mean I can’t just cut a hole somewhere and mount the sub, geeze…Maybe I just bring my Klipsch’s on board?
THANK YOU, I appreciate any nuance or other details I should consider before spending those hard earned greenbacks.
- Sub Location – I conclude either under the Helm or Swing Back – the bench seats do NOT work given the plastic seat encasement. Correct?
- Powered vs Passive – Most marine units are passive. I assume the 5 channel amp/passive sub is best, though recommendations pushed the 4 channel / powered amp – better heat diffusion, easier wiring, independent systems, expandable. Thoughts / experience? I assume in most cases turning off the radio will turn off the powered sub (I don’t need more switches to remember).
- 2 ohm vs 4 ohm. So the 2 ohm is louder/more strain on amp; 4 ohm will let the amp run cooler, some say better sound. Has anyone had issues with a 2 ohm Sub in constantly hot climates (110 degrees plus)? I assume these marine products have this figured out. Anyone regularly run in very hot weather (we do all summer long) and have any issues with their setup?
- Wiring: If I am just adding in the amp and leaving the existing RGB Kickers (2021), will I need to replace the speaker wires to really get the benefit of the amp?
- Amp – Based on keeping my existing speakers, the following seemed to be the consensus on the best “Matched” Amps, depending on 5 or 4 channel, with the higher rated systems allowing for better speakers later. Has anyone used one of these with their existing Kickers with good results & reliability?
- Rockford Fosgate M2 750X 5Channel - $600
- Rockford Fosgate T400X4ad 4Channel- $500
- JL Audio XDM1000/5JL 5 Channel - $1,000
- JL Audio M400/ 4Channel - $500
- Note – seems the 750 or 1000 would allow a future speaker upgrade, and interestingly, because they are larger units, better suited for the heat, per my research.
- Subs: Research pushed the following 4 options with enclosed systems:
- Kicker Tube – 8” = 9x9x14 - cylinder shape- $400 – Passive.
- Smallest - seems this would tuck well into multiple spaces and can be mounted in either direction.
- Wet Sounds Zero – 8” = 18x14x9 -rectangle shape - $800 – Passive
- Concerned about the exposed speaker, largest.
- Wet Sounds Stealth – 8” = 10x10x11 – cube shaped - $700 – Powered
- Winner in size, but powered, need access to 2 sides, but then only a 4 channel amp?
- JL Audio – 10” = 18x13x7 = rectangle shape = $800 – Passive
- That is a lot of floor space, but the downfire mount looks appealing and save from the movement of “stuff”, you could toss stuff on top and not worry about it.
- There were some other cheaper options, but… you get what you pay for….
