Swim Deck issues/questions
MrG
Lake Tulloch Ca
I have a 2012 2575 QCW.
My Orignal swim deck developed some cracks on the underside of it. Bennington was nice enough to replace it and even upgrade it to the newer style with the upgraded swim ladder. So I don't wanna look a gift horse in the mouth.
But my new swim deck seems to have some soft spots in it and I wanted to check with others to see if this is somewhat normal or if My swim deck has issues.
the spot where I'm pointing (in the photo) to on the underside that's not supported has quite a bit of flex to the point when you walk across the deck you can feel quit a bit of flex under your feet. Is this Normal the exact other side dosent seem to feel as much felt and I don't know if it's because the swim ladder is mounted their and it give it enough additional support to make it not noticeable.
this is on the passenger side
You can see the drivers side has quite a bit going on with supports and bolts not sure if this makes it stiffer?
Just wondering if others with a swim deck can test this spot that I pointed out.
Thanks G
You're probably a rare bird as I've never seen a swim deck on a Bennington. Hopefully, others on this forum with similar models will be able to give you some guidance. Good luck...
